I tried the Attblime liquid for 3D scanning … worth $37 ? not really for a little alcohol and rice starch , MINI still can pick it up, but it do not glogging the details as much , but is it better than Zinc Oxide mixture? slightly , in short not worth the money when used with MINI .
The dollar coin do not have that big relief so not much details you can capture anyway … but since MINI can pick-up a layer thickness of 3 µm , I don’t think there is anything better that can be used unless you go into nano particles but I don’t recommend in home enviorment .
You can see a horizonal line where the layer was … next to his eyes and mouth right …
BTW , I went to a vending machine last weekend to buy some water , and in the change I got 5 x $1 coins of the American Presidents collection , 3 of them were the “Godless” dollars from 2007-2008 worth $40 each … nice change
very small 2.7inch around 70mm figurine but lots of details, it was gold so I used 3D scan liquid to keep the details .
Revo Scan used 19GB of RAM for fusing it as I scanned all at once.
8
Not edited as scanned and meshed in Revo Scan , I tried the fused point cloud in CC but the results was the same.
Maybe if I scan it more close up and partial scans, it would have more sharper details , but honestly I am happy with it .
Thanks Eric , it took some time to fuse and I was not even sure it would works , but it did , and the results was optimal that not Revo Studio or Cloud Compare can do better , the difference only that CC was much faster in cleaning and meshing . But the fusion was forever , however the result are great without the hasle of merging individual scans .
Now I am wondering how long it will take to print at 10 inches , I need to clean it up a little bit before .
@Johnathan@Erked
Just raw clean preview … the support is hard to remove from all the cavities so it will take little time to finish and prepare for staining.
Looks great😍 Well done. I have a resin printer, but I’m waiting to buy a FDM printer till I can afford one that prints Ultem. It may be awhile since they are really expensive.
Thanks Eric , I printed at 0.3mm to have the raw look other way it looks like plastic even with 20% of wood , I want the little imperfections . Can’t wait to have it done and finished .
