I have been trying to use POP on my Windows PC for quite some time now.
On Windows (10) it works fine on the hardware side, but when scanning, the software regularly freezes up and frames are skipped. I have aPC with I7 CPU, NVME drives and plenty of RAM.
The only thing it doesn’t have, is USB3 or USB-C ports.
Can that be the issue?
My Dell laptop has both USB 3.0 and C ports, which work fine with my POP, in addition to WiFi (there’s an additional setup button for Hotspot).
The only thing the WiFi and USB circuitry have in common is the whole rest of the laptop (CPU, RAM, etc.), so limiting USB to 2.0 will not affect the laptop’s operation in Hotspot mode.
The frame skipping is, most likely, due to the POP itself and is related to the object being scanned. Try it in Face mode with a willing model (arguably, the POP’s best performance) to see if the problems still occur, then let us know.
The POP is continuously connected and disconnected. This shows in the HandyScan software and also is shown in the Windows Device Manager, continuously refreshes and the 2 camera’s disappear and appear again.
Strangely enough, the refreshing and disappearing/appearing of the cameras in the Windows Device Manager stops when I close the HandyScan software. When I use the builtin camera in Windows, there is also refreshing and disappearing/appearing of the cameras in the Windows Device Manager.
Maybe this was the issue to begin with and it also explains the issue I have with this POP and my iPhone
That sounds like a Windows configuration error. While it doesn’t seem very likely (due to the cyclical nature of the problem), the only suggestion I would have is to review the Permissions in Windows (that’s what it’s called on my Win7 machine, it may have a different name in Win10).
I haven’t tried it on my Mac, I don’t like renaming my Macbook (as I don’t like renaming my iPhone or iPad) to use it as a hotspot, as USB is not supported on Mac. But I connected both my Macbook and the POP to a wifi network called POP, but wasn’t able to connect.
Connected it with USB-C my Windows laptop, but I had the same issue there as on my Windows PC. Continuously connecting/disconnecting, so I wasn’t able to complete a scan.
