If the light have a warm tone then sure, you can use it , you can put it behind your scanner since it looks like big version .
On the left side .
OK Iāll give a try tomorrow! Yes the lamp has three colors, white, yellow and orange.
Thanks!
Would this one also be good?
Ulanzi VL81
It has 3200K and 5600K LEDs, would the 3200K maybe be better for the MINI since itās warmer so less disturbing the MINI blue light? Or 5600K already safe?
It will works , and you can adjust it to your liking. Also you will need to use it on the lowest power settings , warmer tones will affect the gain less so you can adjust the perfect light tone and power with this one to get the perfect balance .
There is no one setting for all , gray surfaces reflecting different than white surfaces . So try to set the light tone using a white object , and later you can just adjust the light power for darker objects .
@PopUpTheVolume āThe attachment for the LED light is printed out with 3D printerā
Could you be so kind as to share your 3D print design for that double Ulanzi mount? I just got two of those lights and would really appreciate your mount!
The one I made was altered base version from someone else , so canāt share it .
But if you can wait until tomorrow, I can make my own new version for MINI and POP2 ?
That would be great! Or I could also make it myself, if you share a picture of how it was done roughly
I wouldnāt want to re-invent the wheel
No problem I want to make the supporting case better anyway so it donāt block the heat escaping from the aluminium and better bottom .
I am not home right now to send you a clear picture , but the cold shoe get above the RGB cam and below it with a very tiny slightly tilt to right as goes the lens of the RGB cam .
Also think about the lower part so it donāt affect the tripod when you attach light to it , MINI have a very small space between
For me not big deal , if I am early tonight home I will make it tonight .
I bought one of these led spotlights and with amazement I noticed that the cold shoe brackets are not the same size as the one on the Revopoint, both the scanner and the tripod.
Do you know if Revopoint uses a proprietary bracket?
We are all looking forward to your spotlight mount 3D object ![]()
Thanks!
Andrea
You can replace it easy, you know that you can change the cold shoe plate. POP2 and MINI can use a regular tripod plate too , just unscrew the one you have right now and replace with the traditional one , same on the tripod. It can all be replaced to regular one .
Yes I am on it today for both POP2 and MINI , did not found the time last weekend.
