That is the final official version of MINI , the others was only for beta users.
RGB is just another term for Color .
Ah, so the emitted light is still blue? Or does it alternate with white for getting texture scans? The scanned texture colour looks really nice!
Thanks, I already wondered why there were two versions and why the Kickstarter didn’t mention them.
Also am wondering when they will anounce the Mini 2.
It was just one version always , we just got early sample before the RGB camera was ready .
It is all blue light as before , the RGB camera do not see the Blue Laser so it can capture the colors for the textures without issues .
The MINI will be shipped in August …
and now you can pre-order in Revopoint Online Store.
Indeed the texture looks better than precedent devices, what max resolution can you export it ?
Thank you for the test!
Hi Xavier,
I have forwarded your request for specifications to the Revopoint Team and await an answer
The answer:
MINI RGB camera 2 megapixel
Thanks, what about the texture itself ? For example is it possible to export it with the mesh , at a resolution of 4096x4096? (4K)
It is 4Kx4K , you can’t choice the size , it is automatic process.
Hi everyone! I’m completely baffled by the magnificient textures you folks could get with the MINI. Can you please explain whether you used specific presets? As I explained in this post, I really have some bad results on my end ![]()
Thank you for your advice ![]()
@Popi they are not as good as from POP2 and that’s the fact , it is difficult to get good colors because blue laser is sensitive to bright light .
The only light that can helps here is LED warm light , the one sold by Revopoint but also available on Amazon .
I am going today to print a special case for the lights to give the shadowless appearance on the objects as I did for POP2 .
Regarding pixelations and triangles , it depends of how big the model is, smaller polygons model tends to have bigger triangles and bigger models smaller .
The best result is to convert the RBG color per vertex data to textures and create new UVs . You will get more uniform textures and no triangles .
In the begining before the MINI release the program did very beautiful sharp textures with MINI but the alignment was wrong , and after alignment was fixed the quality went down a bit .
But I am sure if you work a little bit more on the lighting, your results will be better as that is the major key after all , but it is tricky , I use my Revo LEDs on lowest light settings and do not affect that match the scanning . Keeping the light 10cm to 20cm away from the object . Behind the MINI , one on top RGB camera and one below it as that is the point from where the textures are captured .
Hi PUTV, thank you for your recommendations, I’ll give all of that a try. At the end of your paragraph you’re suggesting that I should use two LED lights then ? One on top of the scanner and one below? Just to be sure.
Let’s hope they will find a way to make both beautiful textures and right alignment in the long run ![]()
Yes that is correct @Popi the way you see here in the photo , I working on the attachment for MINI
The LED need to be set on lowest light brightness so it don’t overpowering the blue light laser , and warm tone light .
One light on top and then be below to avoid shadows
It will give you 100% better results
Oh I see !! Thank you very much ! Are these attachments sold by Revopoint as well?
And what is the little dark remote-looking thing on the right part of the image?
No it is printed , the remote control is for my older Dual Axis turntable to control the rotations and tilts .
I am using now the Revopoint DATT with Android app on my phone to control it .
https://forum.revopoint3d.com/t/android-app-datt-controller/17815?u=popupthevolume
OK I see! But I don’t understand how your Ulanzi lights are attached to the scanner, what do you mean by “it is printed”? Sorry
The attachment for the LED light is printed out with 3D printer .
Which Ulanzi light are those? There are so many different versions on AliExpress… I would like to built a similar setup with two, and a 3D printed mount, looks great ![]()
That are the same one sold also by Revopoint in their store .
ULANZI VL49 2000mAh LED Video Light w 3 Cold Shoe, Rechargeable Soft Light Panel, Portable Photography Lighting for DJI OSMO Sony DSLR Canon Camera GoPro Vlogging Amazon.com
