what ceramic coating have you applied to that surface?
That’s my own brand 3D liquid at 3 microns layer thickness…
For precision scanning of small objects like coins, jewelry , electronics , dental…
Not yet released … ![]()
When/Where can we get it?
Hopefully in 1 max 2 months , I was not happy with the plastic bottles that evaporated too much and upgraded to glass .
I planning already to get it to Amazon as well .
In future production also special hair friendly scanning 3D spray …
Hopefully I will present a samples on a live show soon .
Send me some will gladly pay the cost/post/customs
I want to get it to Amazon EU so no income tax … most of my friends are in Europe ![]()
But no problem … once I am ready you get it …
I’m interested in this too. I hope you manage to get it on to Amazon. Don’t forget about us in the UK too ![]()
of course not Andy !
Hola buen día, estoy presentando problemas a la hora de digitalizar mis modelos dentales, en el momento que se está formando la malla cierra los espacios pequeños lo que hace menos precisos mis modelos. ¿Según su experiencia como se puede solucionar esta dificultad? Gracias por su atención.
Uploading: IMG_0867.jpeg…
Uploading: IMG_0866.jpeg…
Uploading: IMG_0865.jpeg…
Uploading: IMG_0864.jpeg…
Hi @Ligiar
Don’t close up the holes while meshing or don’t use one-click-edit
I can’t see your images they are not uploaded , you click “post” before they were uploaded.
Can you repost it ?
Ok what is happening , the gaps between the teeth are not fully scanned , so it close the gaps automatic
Avoid " fill holes settings" , don’t use one click edit , do it manually .
Make sure you scan it at excellent distance , and try to use single shot mode instead, move very slightly the object each time , will give you better results . One rotation 360 degrees requires at least 32 frames for fine details .
Try to scan as many angles you can in one session.
Muchas gracias
Let me know if it worked for you !
No he podido solucionarlo
Hi! Can you maybe share the scan to have it checked?
