Hi Hamster4000, how did you get the software to open? My M1 Max wont open it.
What’s happening??
My device has a 32-core GPU core M1max with 32GB RAM.
Since it is not a particularly demanding application, there should be no restrictions on running the Revo Metro app itself.
However, the scanning speed is not sufficiently fast due to potential GPU or RAM issues, I guess? Therefore, I am considering upgrading. But if mine has a 64GB setup, I’ll consider holding it till Apple releases the M5max or M6max.
Below is an example of my scanning process with MetroY:
1. Close all applications except Safari for reading the web version of the manual.
2. Connect the cable provided in the original box and wait for approximately one minute.
3. Launch the Revo Metro application and initiate the scan.
4. Ensure that you have the correct version of Revo Metro installed.
Please refer to the attached screenshot for further details.
Hallo,
Ich habe mir auch den Metro Y PRO geholt.
Auf meinem Macbook Pro Max 36 Gb mit 14 Core 32 GPU läuft der Scan mit durchwegs 50+ fps.
Der Prozessor hat dabei eine Auslastung von ca. 20 % aber der Speicher wird schon voll genutzt.
Ich habe einen Scan gemacht mit 25000 Bildpunkten, der wurde in unter 3min bearbeitet.
Gruß Jürgen
Just need to open it from security as it’s unverified developer:
For testing I have a Macbook Air M4 16GB ram, and it scanned at 47-50fps. I thought that was damn good tbh for a circa £1000 device, and so the need to beef my PC up and add an RTX is obviously not that important for a scanning machine.
Das ist eine sehr gute Geschwindigkeit , ohne GPU-Beschleunigung.
