I cannot connect my Revopoint POP to my Computer Win(10).
thanks a lot.
Jessica
thanks a lot.
Jessica
Hey Jessica,
did you connect your POP using the provided USB cable? There should be two different cable, one with USB-A the other with USB-C connectors. Depending on your computer, you should choose the suitable one.
After connecting your POP, the tiny LED on its back should become active (either green or blue; I’m not entirely sure about the LED colors yet) and your Windows 10 should recognize “some” USB device and show a notification.
Did this happen for you, or are there any issues with this already?
Regards,
David
Disclaimer: I’m a POP kickstarter backer myself and only get started with this.
Hello @JessicaCS , can you check this post first please.
And also, are you sure than your USB port are a 3.0? ( Blue color inside)
Thanks
Just a little thing in case, unfortunately on some newer PCs the USB 3 isn’t blue anymore but back to black (have seen several Dell and Lenovo Notebooks and I’ve read that it’s not anymore a reliable identifier), sad, that was useful
I am curious. It appears that you can scan, but you are not happy with the scans you are getting.
It has been a while since you posted, so please update us on your progress.
