Hi @kanakaRed you don’t have to fuse your scan after scanning , just return back to Home tab after your stop scanning and start new scan …
Or
You can import your project to PC and process it at full quality .
This option is for a long time already .
Or
Right now on the Android Mobile app the quality is the worse it even was , the textures are so blurred out it is completely not usable for anything , before you could at least share it via Internet but now it is just s blob not even good for preview .
There are not white balance settings when capturing the color , so the colors are patchy as the light change so the colors .
What I would like to see
White balance settings ( a standard setting for capturing a color data )
An clear option for fusing, meshing or texturing , not one click edit option as it is good for nothing with this quality at this moment .
A clear option where you can decide if you want to start a new scan without the need of processing each time , meaning a new scan option . As many new users don’t know they can start new project without the need of wasting time processing scans that are good for nothing . Not usable so why bother with the processing at all .
Single shot option
Ability to have a different preview shader
Option to keep the App ON while use
Hi @PUTV
Thank you very much for your advice! The first 5 are already planned. I’ll feed point 6 back to the product department, and thanks as always for the excellent advice! ![]()
The ability to connect the smartphone to a computer via WiFi. In order to use the app as a UI and screen. And scan with the power of the computer.
This is one of the most bizarre request I ever heard
Why you would like to use a low capacity app for ? If you can use full power Revo Scan 5 on your computer? That produces full quality .
Just scan on your phone and process on your computer … mobile app will not give you that power processing as it is not capable of doing it .
I find that the feature tracking is much better on PC. and this could extend the distance to the PC. A while ago I wanted to scan something in my car. Tried for an hour with the app without any useful results. then linked an old laptop with remote desktop to my PC and a few minutes later it was ready.
You can also use an Android tablet with a desktop remote screen app or an Android phone for that matters and not the other way around . And scan on PC using your phone or tablet as monitor only .
Personally I got tired of using Android tablets and phones and got myself win11 Dell tablet/PC with 16GB of RAM and i7 processor … and that was the best money I spent to use with all my Revopoint scanners… scanning now direct to flash drive with an easy way to move my projects between computers without importing exporting …
Simple is beautiful
Trigger/Control Turntable…
Features I would like to see on mobile:
I know this is a lot, but some of these could be game changers when scanning on the go.
A great an important Feature would be the possibility to use Feature and Marker Mode at the same time.
Shining 3D Einstar is supporting such a Feature.
Thanks
Hi @theFlow
I don’t see it support any feature on a phone … or even works on a phone .
We talking here about features on a MOBILE devices and mobile apps .
Yes,Einstar is Not working in a Phone. But Revopoint is…so I Just ASK for the Option to Use Marker and Feature Mode at the same time. Should be feasable. Miraco/App and also in PC mode.
EDIT:
Just saw that Video: https://youtu.be/qbZWnNwTDYk?feature=shared
On 1:15:40 Someone is asking for the same Feature.
In my experience with the mobile software, I came to the conclusion that in the stage of creating the mesh, an option for setting is needed to have a better output
in old software revoscan v3 output is very vetter than revoscan v5
Version 3 don’t offer your full projects to be meshed on computer . You will never have full quality on mobile , not enough memory to process it .
The whole workflow and process was changed in V5 in fever for having actual full project what is much better option overall.
I want to use this app for detailed control of my turntable. While I understand why the features have been implemented the way they have for standard scanning, I have other applications that require an improved feature set:
I need to be able to enter tilt angles in numeric form. The slider used to control angle is poor at best…I cannot hit the values I need easily, and there is no indication of what the current angle is on the slider until you Save. It should be easier than this.
I am allowed only to rotate the turntable continuously. I want to be able to step the turntable in defined increments (like 5 degrees). I want to enter this number manually, and have a separate control for manually stepping and not just continuous motion.
Hi @Dana_Bourke
In main time use this app to control the DAT you will have all control you want
