Revo Scan 5 MetroX V5.6.1.82
Win11 (all updates applied)
PC: Lenovo Legion 5. i9-14900hx, 96GB RAM, 4060 8GB.
Stability. First release, so it is expected there will be bugs. But at the least, it would be nice if crashing were less frequent. I seem to get it less than others, but it does happen.
Better marker tracking. It’s not unusual to see them shown in the depth preview as overexposed, but it doesn’t track them. Sometimes it’s angle or distance, but it would be nice if it were a little more flexible. I get that it needs to be precise, so obviously that is the priority.
It would be nice if the lasers were more visible on the screen. When adjusting distance to get details that are slightly out of range, the lines help a lot to know that I’m getting the detail I need. It might be enough to let me pick a zoom level. I find it likes to show me more data than I care about most of the time while scanning.
Feature tracking could use improvement. I’m sure you are aware.
Maybe add texture tracking.
GPU processing. Please get this working.
Better multi-threading. I know this is difficult, but it would help a LOT of people. And you likely need it for GPU anyway. Smaller units of work, spread across more cores. For an easy win, when using batch processing, run them in parallel. Right now, it’s only hitting 2 cores. I have 24.
But at least get the performance cores going!
Merging can be difficult when thin objects are scanned. Think PCBs, SD cards, etc… Getting the other side can be difficult and merging often puts them back to back. Being able to rotate them to approximately the right orientation and then clicking points for manual alignment could help. Might be better options. Even when they do line up, I find I lose details sometimes. It’s like they are merged slightly off and it blurs the details. There might not be a ton to be done, but figured I’d mention it. Maybe if existing data is high quality, let me mark it to exclude merging into that area? I don’t want to remove parts, I might need them to align scans. Or a mode to fill holes only when merging?
It would be nice if mode switching were a little smoother. It basically hangs the program while it switches. It would be nice if that were a background task at least. Perhaps let the user pick a few options and THEN change the scanner mode? There are a lot of options. Kind of annoying when I want to set up a different scan and every click is a 20 second delay. I don’t mind the scanner needing a moment to adjust, it would just be nice if every UI click didn’t send a command needing that delay. It’s also started telling me there is a low frame rate when changing modes. Well, yeah, no data should be coming in…
It would be nice if when I select a mode other than auto turntable, it doesn’t run the turntable when I start the scan. Maybe a checkbox over near where the mode is set to enable/disable starting it up? Maybe some people want that. I just figure I’ll push the button on it if needed. Yes, I can disconnect it. If that is the preferred solution, please make it easier to disconnect it.
Ended up being a slightly bigger wall of text than expected… sorry about that.
