Part List: POP 2, Power Bank, Phone Holder, 2-in-1 Mobile Cable, Sample Statue and Portable Turntable.
- Connection of the Turntable;
Part List: 2 pieces of extended table, USB cable, Detachable glue and the mini turntable.
Connection:
- Power the mini turntable via the USB cable;
- Splice the 2 pieces of extended table into one plate;
- Stick the detachable glue on the mini electric turntable;
- Then Put the 2-in-1 plate on the glue.
A new turntable is obtained.
- Hardware Connection
Part List: An Android Smartphone, a 2-in-1 Mobile Cable, A Phone Holder, a Power Bank And A POP 2 3D Scanner
Connection
1)Screw the phone holder on the power bank;
2)Fix the POP 2 on the phone holder;
3)Connect the 2-in-1mobile cable on the rear of the POP 2 3D scanner, and tighten screws at both sides;
- Fix the Android smartphone in the phone holder;
- Connect the 2-in-1 mobile cable to the power bank (Type A) and the smartphone (Type C) separately;
Open Revo Scan and confirm Settings;
Before scanning, confirm the Connect Mode to be USB Mode; and select proper Accuracy, Scan Mode, Texture and Model Format according to your demand.
Click “New Scan” and authorize the camera;
Adjust the brightness in RGB and depth camera;
Note: Auto first, then Manual;
Click “Start” to scan;
After completing scanning, perform Point cloud fusing and Meshing;
Check the 3D mode scanned in Project ;
Export the 3D model to another device:
