I looked for scanning cases that were outside, however i did not find any.
How is the scanner reacting to light exposure? When the surface is for example reflecting white and the sun is shining on the surface. Is it a problem for the scanner?
I would really love some examples that show me the capabilities of the scanner being used outside on different objects.
The scanner can’t be used in sun light
The Depth camera sensors will get blind from the brightness of the sun light.
So the best option od to use indoor or in shade
It is not made for using outdoors and definitely not in sunlight .
Sensor settings do not increase the laser but overall exposure of everything , the settings for laser brightness are very high , but still not for use in Sun light , that is like using flash light outside and expecting to make things brighter than the sun , will not work .
Good shade will works well outdoors but not in direct sunlight.
You will need to recalibrate the scanner first , just the manual calibration after you put on the lenses , not sure about the Inspire 2 lenses, they are different from POP 4 or MetroY ultra lenses that was made for NIR and the Blue laser , the other made for Infrared only.
But nothing stop you from using it , just after you put it on , recalibrate and use black object settings , the distance may get little shorter
