SOLVED Miraco pro, calibration bug or problem
hello im a new user everything was ok bit of fast scan made then i saw an update is available did the update and tracking problem and cant make ani calibration, when i hit the right height all degree and height become grey and cant pass to the next step, i try normal no light , with light , with a spot light nothing help,
what is the trick? or is a bug in new firmware?
using revoscan 5.5.0.1579
app version 1.2.1.31
system version 2.6.38.20241025
imu calib work and its done
version when i receive it was far 1.0.something
brand new scanner that i cant use not fun but shure is a way to fix
anybody have a clue?
There should be no bug anymore calibrating MIRACO since I updated my 2 units and had no issues re calibrating .
Sometimes the levels are tricky
To keep the device at the specific angle .
Why you don’t put MIRACO on a tripod and then hold the board in your hands and adjust the angles
It works both ways , of you move the device or you move the board .
Try that , it is much easier
Maybe sure you have enough lighting in the room that coming from behind the device direct in the board .
Also make sure MIRACO LEDs are in while calibration .
pretty shure its related to firmware i did it before and all was good
will try to make a video tonight
I updated 2 of them with the same firmware so it is not the firmware .
The firmware has nothing to do with calibration , the PS5 computer software do
Do you have still the older Revo Scan software ?
I would recommend to try the older version for calibration that worked early for you , not the latest version .
It worked before for others , it may for you , until the dev team finds what is really going on .
i saw it cant find any link that work i ,got the latest version
I will send you one today to try
calibration work good with old version of revo scan if some get problem !!
No calibration Bug with me and my plus.
Yesterday i have calibrate them.
its not every one, only some hardware i think
It has to do with the old MIRACO and MIRACO Pro calibration board and new computer software , there are some issues with it .
MIRACO Plus have new glass board so there are no calibration issues .
For anybody having issues with calibration of Miraco please contact customer@revopoint3d.com
For future assistance .
Since this issues was solved
I will close next e this topic .
