Software very slow and not using the full PC performance
Dear all,
I did a scan today, should be very detailed and took me several minutes to scan. After the scan was done, I used the OneClick solution and it shows an estimated time of 62 minutes. However, the performance of the computer are not used and CPU as GPU are less than 17%. For me the Software works not with the full performance. Also the RAM was only at 20%.
At the end the job was done after 15 minutes. But please use the full hardware performance we have to get a quicker result. We bought very expensive Laptops to do quick scans.
Thanks
Hello,
I have a 5950x Win 10, 128gb RAM, 4Tb m.2, 3080ti and an RTX 4000. At over 30,000,000. Triangles make the system slow. I just noticed that Revo Scan Meteor X is not using the system to its full potential. Is there a way, like with 3df Zephyr, for example, that you can switch on the “system info window”? So that you can see in detail how Revo Scan uses the system’s resources. Because my graphics cards and CPU have nothing to do according to the task manager. Would it be possible to make Revo Scan Meteor X more efficient? In addition, an abort button would be really good to be able to abort a process if it takes too long and you would rather change the settings again.
It is the same here - using a powerfull AMD 5950X with 16 cores / 32 threads and 64GB RAM. During Oneclick solution it says in each step “estimated ~1min”, but it took much longer in each step and the CPU in Taskmanager is only at 8-21% and just ~4-6 cores seem to be in use, but not full throttle = WAITING…and more waiting… :sleeping:
Revo Scan 5.5.2 on Windows 11 24H2
Revopoint Miraco with 16GB
Hi! Same config here, same results. We are all waiting for the performance updates, which surely will come incl. GPU accelaration. A bit more patience needed.:no_mouth:
Patience? I am trying for years now. Last upgrade was a 3090ti. Still too slow.
What have 3090ti to do with processing of your scans ?
Only CPU is used for processing
It also depends of the speed of your SSD .
Revo Scan 5 MetroX is CPU based software so processing go through CPU only.
I never had to wait that long , as long you do not open other programs while processing you should not wait too long .
Users complained a lot when CPU was running at 100% .. you never can make everyone happy .
Use the recommended system , you should not wait long for processing.
for my case, it never use up all threads , only half CPU was used, and its not overheating, what i can do is hope it will be fixed for next update
It will be better in the future , right now it runs already at 75% in upcoming beta version with recommend system.
Remember the processing writing down a huge text document .
Even Zbrush can’t write things faster with all threads when working on big model.
Fusing is not a huge task process but meshing and then texturing takes the longest in any software with a models that are constructed with so many points.
