That is not what I was talking about , I was talking about the time that your computer spend cleaning all the overlap frames you create while scanning . You are not taking a video of the object, you capturing the objects faces, different angles of the same faces will create overlapped frames that need to be cleaned and it take time . So you can make your life easier if you do it the way you should and not following your common sense, as common sense is not common after all
It is not about what is better , it is about what are your skills in 3D modeling and what you can do, the automatic texturing is for people that have no clue how to do it or want to spend time learning other programs . In professional work the textures are not usable for anything the way they are generated at this moment , but improving are in progress so it may be better especially for MINI .
Not really professional , but for anybody that is interested in 3D modeling or at least want to learn the basic to better understand what they are doing . There is no scanner in the world that make a perfect scans for you by a click of a button , this services are very expensive as it is time consuming work , POP2 or MINI provides so good results it almost cut my work in 3-4 weeks .
You can follow the Auto settings that Revo Scan offer, if you have no idea what settings you should use , setting everything on high will not always deliver what you want . So Auto settings will be the answer, and I tested it and works very well especially for fusing , saving lots of time .
Looking forward to it , remember that the speed of your RAM also make a huge difference here and of course as always M2 SSD what in my case it write down with a speed over 2250 MB/s a data the size of 1GB compared to regular SSD at over 500MB/s and Normal Hard Drive at 140MB/s , it also depends of what size it handles, how bigger the size how slower it will be.
So everything is connected here .
I don’t have issues with that , everyone has own workflow , there is no one workflows for everyone , as everyone think differently, and have different kind of system to work with , as they say no all dogs names are REX . You need to devenlop your own workflow , as I mention before the Auto settings are very user friendly and everyone without knowledge can follows it , 3D Scanning is like 3D Modeling , you need to evaluate your object, make plan how to approach it, if you are looking for a click button and done , you will not find it anywhere no matter how much money you spent on scanner, how more expensive how more difficult it is to produce proper scan , as scanning is just a half of the medallion, you need also be able to process it to some level .
I had many suggestions regarding the UI since last year, but nothing was really taken in consideration , not even dark mode , beside the buttons names
nothing was changed so good luck! Suggestions are always welcome … as long it don’t downgrade the scanning quality again as it happening so many times already . You see one software build has perfect and fast point cloud, the other has wonderful textures , but somehow nothing come together into one build yet … it is always something missing or get broken on the way . So be careful and know well what you wishing for …
BTW I tested human torso scan on my new Android octa core 8GB RAM tablet and the fusing was faster than on your first video with the bust , I did overlapped some areas on purpose , but you see Android app has superior point cloud fusing with POP2 that I am missing in Revo Scan since February …
