SKREETKAR 3D | TUTORIAL | MINI 2 RE
Order your own Mini 2 here:
https://bit.ly/3vTIaaz
SPEEDRUN to Part Creation
Revopoint Mini 2 Scan Mesh
GOM Inspect Alignment, Fusion 360 Reverse Engineering
Twin 65mm CobraJet Throttle body Parts Modeled:
8mm Thermal Spacer
Spacer Gaskets
ROVAL Bellmouth Velocity Stack
Target Parts:
Start in RS and export mesh STL:
Open GOM Inspect and Preform initial 3-2-1 Alignment:
Import mesh into FUSION360 and the tutorial video above, use scan stetches to create your desired parts:
Assembled Parts:
