Scanned object, but i see selection tool is related to direction.
Let say i see in point cloud what i want to delete, i try to select them i cant, i need to rotate camera to point direction, then i can select and delete.
If this is by design fine, but then how to delete these points as it is from other direction, if i select view to that direction i don`t see points because of density of them…
Exported my clean point cloud to mesh in Revo Studio and meshed at Level4 ( meshing levels in Revo Studio do not correspond with the level of meshing in Revo Scan , level 4 in Studio is Level 5 in Revo Scan etc
i have followed your tutorial it is superb.
Regarding poisson recon plugin - i need to work with it as it created too bumpy surface.
Cloud compare looks very powerful, but poor interface software.
I like that It does job very well.
That’s true , objects like yours I prefer to mesh in Revo Studio and use denoiser after ( not geometry smoothing), if you get too noisy surface in CC lower the settings under Poisson Recon plugin …it is more of a trial and error , but usually between 8-9 do the trick.
Having too high level of meshing not always bring desired results or more details , after all you can’t bring more details than the point cloud offers you in the first place .
Meshing at higher level in Revo Studio like 5-6 then use denoiser will do the trick after you cleaned it in CC.
Thank you again for your time answering. From my side one question related to accuracy. Maybe you can point to CC or any other tool to measure object between features, points or diameter, length etc. ? As i need to check that.
