Revoscan5 USB Binding on an Mac M2 Ultra
Trying to run a Pop3 and Mini2 camera via USB-C cable to a Mac Studio (M2 Ultra running up-to-date Sequoia and current Revoscan5 build). When connected Revoscan5 fails to see the cameras.
The Mac sees the devices on the USB Hub and recognizes them correctly.
When running the app via Terminal with verbose logging and monitoring in Console I get the following errors:
Error from Terminal: probeMain–ossconnectwithtimeout–failed! 127.0.0.1-14075
Error from Console: appleusbhostuserclient::opengated: failed to open usb3 gen2 hub@06500000: provider is already opened for exclusive access by AppleUSB30Hub
This error persists across users, different cables (including original), using external hubs (with and without power), software reinstalls.
This does work on an M1 Max studio (Tahoe) and a Macbook Air (M2, 2022). I have limited Macs at my disposal for testing, but this seems specific to the M2 Ultra chipset.
From what I am reading about the M2 Ultra chipset is that it controls the USB roots more strictly. The failure to bind is telling me that Revopoint’s software isn’t allowed through the AppleUSB exclusivity. If this is a kernel level driver conflict or some design-level limitation between the Revoscan5 platform and the architecture, I don’t know enough to determine.
Throwing this out for anyone else experiencing the problem or has any thoughts.
Thank you for your time.
Hi @adennis_dmu
I would recommend you send it to customer@revopoint3d.com including the link to this thread. You may get more information from the technician regarding this topic.
I have the same issue on M1 Mac with Mini1. Mini has green light, gets recognized from mac as “REVOPOINT_PRODUCT” but don´t get recognized from Revoscan 5.5.5.
It happpend last time when I wanted to scan..at the end I deleted everything related to Revoscan and reinstalled it and it worked. Now with next scan some days later ..same problem.
I´m on macos 15.6.
Anyone know what can be the problem?
Thanks in advance!
Hi @Skyrider
Try to switch the USB C direction , if still nothing please contact customer@revopoint3d.com for technical assistance.
Hi, thanks for your answer. I tried this before, made restart, different USB connection, deleted preferences etc but nothing helped. It worked again after deleting and reinstalling Revoscan. Hope next time it will still work. Not the best option everytime to delete and reinstall. One thing also kept my attention: I always have to force quit Revoscan because it doesn´t shut proper on it´s own…
Yes, I might contact them if next time same thing happens.:crossed_fingers:
