Mathieu
February 1, 2024, 11:01am
1
Revopoint Mini 2 advanced edition
serial : A23A-XXXXXXXXX
Hello,
I have just received the Revopoint Mini 2 advanced edition.
I have updated Revo Scan to: RevoScan5-5.4.3.724-windows-x86_64.exe
Connected to PC with USB Type A to Type C cable
The scanner LED lights up green,
But the scanner is not recognized in Revo Scan,
message “scanner disconnected”.
I disconnected and reconnected, tried the other 3 USB ports,
also tried the type C to thunderbolt adapter
switched the PC off and on again, without success
Tested on 2 differents PC with USB 2.0 USB 3.0 USB 3.1 and on thunderbolt with usb-c adapter.
(note : previously Revo Scan worked perfectly with Mini 1)
Note : Mini 2 works on wifi perfectly, but I want use USB.
Regards
Hello @Mathieu
I’m sorry to hear that.
We’ll get this back to the dev team and test to see what the issue is and get back to you!
Ok thank you. I wait
Possible bug RevoScan5-5.4.3.724 ou USB cable ?
Hi @Mathieu
Can you please send this question to our customer service email at customer@revopoint3d.com ? They will handle it centrally.
Alternatively, you can provide me with your email address, and I will have them contact you.
PUTV
February 2, 2024, 12:01pm
5
Hi @Mathieu please try the split cable and power it separately or even connect both cable to your PC and test out if connection works fine , if it is working , it means there is issue with powering Mini 2 via one USB cable .
We are currently also experiencing this but for the MINI and the Pop2 instead. Uninstalling 5.4.3 and reinstalling an older version of the software did not fix it for us.
PUTV
February 3, 2024, 5:14am
7
hi @alhendrix96
Please contact customer@revopoint3d.com for future assistance and technical hardware support .
Ok, like I read in other post,
I plugged the 2-in-1 Mobile Cable on PC and power bank, and it works.
i replugged the standard USB cable and it works now.
problem solved
Hi @Mathieu
Glad to hear it! Can I ask which post solved your problem? I think it could give us some clues .
PUTV
February 4, 2024, 7:34pm
11
Mathieu:
problem solved
Glad to hear that, it works always in my case . Next time you have an issue just use the split cable .
It is actually the system issue that do not use the proper USB driver in UVC connection mode .
Titon
February 8, 2024, 11:52pm
12
I too just received the scanner and i have to connect both the usb cable and the c connection as well?
So now we have to use 2 cables?
PUTV
February 9, 2024, 12:29am
13
Just connect the white cable that came with the scanner , change the USB mode under settings to Transfer mode to import your projects to computer .
Where you got the idea of 2 cables ? There is only one USB port C .
Do not connect using the black turntable cable , it is only for power the turntable , no data cable .
You can also use WiFi to import your projects without any cables .
Titon
February 9, 2024, 11:42am
14
My mistake. I did accidently grab the wrong cable. There is no white cable in my kit but I did find the correct cable and am up and running.
Thanks
PUTV
February 9, 2024, 1:33pm
15
Sorry mixed the cable with MIRACO cable
You use Mini 2 right ?
Anyway glad to hear it worked for you !
The split cable works best for best performance especially on laptop of PC .
Titon
February 9, 2024, 7:17pm
16
Yes i just received the mini 2. I was using the mini but am already seeing a big difference using the mini 2.
hello,
i am having this kind of problem also.
my revopoint mini 2 is not connecting on revoscan, it always disconnected.
i tried connecting it to mobile, it works.
but i needed to connect it to my mac, to make my work more easier and faster.
hoping that you can resolve this issue.
thank you.
PUTV
February 20, 2025, 8:43pm
18
Hi @garyongco
For technical assistance with your personal issue . I can’t do that here in the forum .
They will help you out
Hi is there any other solution?, RevoScan does not recognise Mini 2 using USB. I’m forced to use Wifi
PUTV
August 6, 2026, 12:57am
20
Hi @careuno
Get yourself a good thunderbolt USB C cable that support at least 8 GB data flow and support charging . it will works .
This type of issues are related to the System and your USB port and there is not really anything else that can fix it , reinstalling the USB ports may help .
But in my case a good cable solved all my USB connection issues .
