Revoscan Software - raw vs fused vs meshed
Try to scaned a panel by Marker tracking-general-crossline mode,
the raw and fused looks reasonable but when try to mesh important parts are disapeared like this
Would someone guide how to convert a bether meshed model to export ?
My guess is that the mesh algorithm couldn’t see a connection and stopped. There are a lot of holes in the scan. It’s not surprising with the mesh grid, but you are probably going to need to scan it better. It can be difficult to tell how good it is doing in little areas, but you can pause, zoom and pan to get a good look.
Are you doing 1 click? It looks like you need more data there in the center. Not enough points currently. What are your fusion and meshing settings?
You missed a lot of data from the middle scan area , not enough points to connect .
I would redone it making sure you capture everything without leaving any gabs .
