Merging issue filled holes are gone in Metrox Revoscan
Hi,
I don’t know if it’s lack of knowledge or an issue.
I want to merge 2 parts. For that I took two scans (just a test, not perfect) filled the holes and wanted to merge them. But in merge function (of meshes) I only get the two parts before I filled the wholes.
What is the hidden secret?
Regards Thomas
merging merges point clouds, not meshes
Yeah, you merge fused scans, not meshed. This is why you see the holes back
So what is the problem?
I meshed the fused point clouds and when i switch to merging I get only the point clouds and not the meshed ones.
So does Revoscan only merge the point clouds and not the meshed ones?
That’s correct. You need to mesh again the merged model
BTW I am very happy about the resolution of Metrox if you look at the arrow and „top“ and „oben“. Its less than 50microns and still seen well after merging and simplification of the mesh. And the material is black matte PP.
  1. Scan your objects
  2. Fuse the scans and clean them up
  3. Merge all the scans ( point clouds)
  4. Mesh the final merged scans
  5. Export
So I did at the end.
Thank you PUTV
I hope you got the results you hoped for, thanks for letting us know !
