Move the information window, it gets in the way very much in the center.
Move the model display buttons to the panel.
Add a light source Ctrl+L) the “closer/further” function, not just moving. For example, the DI is the movement of the light source in the viewport in the plane, and the Wheel Mouse is the distance/approach.
It’s indicator that the scan is in a pause
And need start scanning , shifting it in the corner will not not make the notification clear to the user , but I would put it on top the preview scan if you want to check the progress .
Well, at least down the center. But that he would not block the center of the viewport. This way it will be easier to hover and continue scanning, it is easier to make sure that the track is correctly picked up.
