Der Scanner Revopoint PoP und das Modul GripGear kombiniert ergibt mehr Freiheiten im scannen…
The Revopoint PoP scanner and the GripGear module combined result in more scanning options …
#3dscan #revopoint #gripgear #hobbykind
Great suggestion, but - sorry - catastrophic and agonizing “music”.
P.S.: Also the suggestion is a bit useless without any information about what “grip gear” was used. Model? Producer? Product link?
P.P.S.: Seems to be this thing: https://www.amazon.de/Directors-Electronic-Slider-Panoramic-Mount/dp/B07GTF4VVD See? Easy to post a link.
Grip Gear Directors Set - Pocket Sized Camera Motion Control kit for All Cameras Less Than 1.5lbs https://www.amazon.de/dp/B07GTF4VVD/ref=cm_sw_r_cp_api_glt_i_2FJPG0DNMZQ2JY2NFSVR
Right, thank you. Sorry for sounding angry, I just have gotten pissed by reviews at Amazon, for example, too often that go like “This item is crap, I found a far better one” without mentioning what exactly the better item might be. Sorry for transfering this anger of mine to your very helpful suggestion (even without the link). Something like that is actually an addition I thought might be very meaningful, and I was even thinking about construction something similar on my own.
it sounds better that way
i understand your frustration! To be honest, the only negative thing about the device is that it can only be used very slowly in curves. this is too slow for video recordings! but this option with the rail is perfect for the scanner! I now only need a large turntable or a construction that moves the tripod with scanner around a person.
