RevoPal on my Galaxy S10+ works fine with the new large turntable but only connects to the 2 way tilt turntable. The connection is made but it will not control the smaller turntable. Older app Serial Bluetooth still works fine on the phone.
I am not exactly sure what is happening.
When you connect the Large Turntable it connect to the Dual Axis turntable in the app and not to the Large Turntable ?
Or you mean that the Dual Axis turntable do not connect at all ?
Can you please explain .
Also please connect only one turntable at a time before you start the app and connect the scanner .
Both turntables connect. The large works fine with the phone but the tilting one does not.
Ok thanks , I will have to check it out tonight and confirm it .
