Recalibration query
Does the Miraco or software tell the user to recalibrate please? How will I know when if there’s no visual or audible indication. Thanks
Hi @Revo_Girl , you should not recalibrate the scanner , the calibration process take a while and if you do it wrong you make it worse .
The indicator that your scanner needs recalibration is simple , use marker mode with marker plate , if the markers are fully visible in red , you don’t need calibration , the only cases that tell you that you need recalibration are ghosting of your scans like double features or the markers in marker mode are not clearly visible.
I highly recommend that you stay away from calibration if not necessary , if you don’t have significant issues it will not make scanning better .
Lose of tracking is related to objects without proper features .
So that’s the last thing you should worry about .
I see many people calibrating their scanners before even using it, biggest mistake ever .
Thank you for clarifying babes. So basically if support says if there’s issues. Last resort
Pretty much, yes. The scanners are calibrated from the factory.
Thank you so much for your help
