hello,
i bought a miraco pro to scan window profiles to see if they are well assembled.
i got the miraco yesterday. i tried a few scans but i always get alot of deviations if i compare with my caliper. (23.9mm instead of 23.3mm)
the scanned piece is always ±0.6mm bigger then i measure with my caliper.
how i work:
i cut 10mm from the profile, put a grey/white paint on it.
i use the small turntable on the slowest speed.
i scan one tour of 360° on continuous mode ==> ± 700 frames
the scanner is installed on the tripod.
i already added the marker topper and used marker alignment.
Scan settings:
Accuracy high
Alignment i tried both settings, same result
Object type general
Color is off
near mode
both windows on the left are on auto
for the mesh settings i tried already alot of different setups. always the same result.
does the device needs to be recalibrated? or how can i improve the precision?
picture:
