Hello, I have been following Revopoint products closely for a while.
I have also read many topics in the forum. Thank you for the information you shared.
I have some questions before purchasing in order to choose the right device.
I am undecided between Miraco Pro, Miraco Plus and MetroX.
I have been working as a CGI artist for over 20 years. I am an Autodesk Maya user. I am interested in Solidworks and Quicksurface. My goal is to collect point cloud data with Scanner. I plan to do the mesh creation process on a high end PC.
It is important for me that accuracy and texture data.
I will mostly scan objects such as car bodies, engine parts and game assets to produce them. Sometimes I will just scan the place where the part I will produce will be placed.
Apart from the zoom and metrology kit, is there a technical difference between Miraco Pro and Miraco Plus?
Can I use the metrology kit with Miraco Pro?
Can i use MetroX in outdoor?
Can I use MetroX with a high end smartphone or tablet to collect point cloud data?
MetroX are 4 scanners in one and is my favorite scanner to date .
Can scan mostly all materials without 3D spray
Miraco have 2 scanners in one and only infrared and require 3D spray on surfaces like metal, metalic , rubber and other absorbing light materials .
Great for scanning humans, on the way, compact and fit capture color data on the way
Personally I would choice MetroX if I had only one option.
That’s why I have 2 and use the proper one for specific job .
I agree with PUTV. If I could have only one scanner I would choose MetroX. I can make it work for me on pretty much any object I throw at it.
However, I love my Miraco Plus and it tends to be the scanner I reach for in the first instance due to requiring no setup. The same can be said for the Miraco Pro too though.
I don’t think you’d benefit from the metrology kit of the plus based on what you said your use case is.
