Photogrammetry of miraco plus used with metro x
Hi Guys
I would like to combine the volumetric precision of the photogrammetry of the miraco plus with the loca precision of the Metro X
the idea is to do the acquisition with the miraco plus then import in the pc the .mkf file generated and the start to scan with the Metro X on this grid
in this way i can achieve an amazing result also on big distances!
i’m quite sure it can work because i tested it with the miraco plus and the Range … but i need to be sure it works also with the MetroX
Can someone help me to test it out?!
it would be a gamechanger for Revopoint users,
this solution could generate a result equivalent to high level professional 3d scanner such as the kscan magic 2 from scantech (60k) at an affordable price (3k)
