Nickluvin's Miraco Showcase
Hi everyone!
I’ve had my Miraco for several months now and am finally getting around to posting some of the projects I’ve used it for. I purchased a scanner mostly for reverse engineering parts and creating custom vehicle parts.
Backcountry ski binding fix:
Last project of mine has been for my backcountry ski bindings. I had a small piece that broke and then disappeared from my binding, resulting in them not working properly. This is an older Dynafit binding and its hard to find parts without buying used/broken ones to scavenge from. So I did what any good engineer would do and 3d printed some new parts. Here is the part that was broken and missing on my other ski
I started by pulling apart the binding to get to the remaining part out so I could scan it. This is a very small part, seen next to a US Dime for comparison. I scanned it on the turn table with some other objects on there in feature mode. This allowed me to capture it. I was actually surprised how well the Miraco did with this considering the size.
I’ve played with QuickSurface for reverse engineering but still struggle a little bit with getting it to do what I want. For this project I used Xtract3D plugin within Solidworks to reverse engineer.
After printing a few test pieces and tweaking out of PLA, I printed the final parts out of PETG-CF on my Bambu A1. It came out great and allowed me to fix my bindings.
Outdoor Faucet Tool:
I had to fix the vacuum valve on my faucet outside. Its hard to get the the plastic piece in there without using pliers and chewing up the outside. So I Scanned the part and made a 3d printed piece to screw it on.
This one I did use QuickSurface (QS) for the reverse engineering
Here is the workflow in QS:
Start with creating the most basic solid
Extract a sketch from a slice
From this slice you can fit lines and splines to the part to create a sketch
You create another solid from this sketch
A boolean operation removes/cuts one solid from the other
Doing this a second time gives the following
Add a few fillets and presto!
Then you can see how well you did by doing a comaprison to the original scan
Tail light housing
I had bought some tail lights for my truck off of amazon but didn’t realize they were the type you were supposed to cut a hole for and do not flat mount. The return window came and went and I was stuck with some lights I didn’t quite have a way to mount up like I wanted. I figured this would be a good scanner project. Here is the original light, the 3d printed housing, and the final product.
I started with a scan. not the cleanest scan, but enough to give me what I needed.
This was another Quicksurface project to reverse engineer and end up with a solid.
After that I bring it into Solidworks and design the housing for it.
A 3d test print and a few tolerance modifications later and I have a part that works.
Print out of PETG and a little bit of paint. If you squint its mint! I thought I had a picture of it installed on the truck but I guess not.
Hi @Nickluvin
Great results thanks for sharing!
I think I shared this scan a while back, but here is the final product.
Scanned the front of my truck so that I could design and build a bumper to hold a winch. Was scanned with my Miraco pro at the the time (before upgrading to Plus) with markers.
Was brought into Solidworks and used Xtract3d to orient and create planes.
Designed plates to weld onto the frame and then bumper around cad, no real reverse engineering on this one, just building new cad around existing scan.
Final product
Great stuff as usual Nick , thanks for sharing !
Have some more automotive projects I’ve worked on. I have a Tahoe I put a 1 ton axles under. needed to build a front bumper for it. Scanned the front end and the winch (ssshhhhh, I scanned the winch with my MetroX).
Designed a bumper to fit the frame rails and hold the winch
Finished Product
Anyone who is worried about volumetric accuracy. I did 4 separate scans and merged them together of the inside of the vehicle for a sleeping platform I am building. Used global markers to get a good marker baseline and then scanned in Far Mode. Got all my scans merged together and into cad. Did a measurement from wall to wall and got 66.6” Went out there with the tape measure today and was just a tad over 66.5”. I’d call that pretty darn good!
