on this project I needed to make a full roof mould to be able to make new roofs the same as this one we have made from scratch
the problem was that the shape made it impossible to do it in one piece so I used a scan done with the Revopoint MIRACO 3D Scanner feature mode ( I could have used Range 2 or any of the other scanners in marker mode to scan it )
to create a cut line in Fusion 360 and use my 1400 x 900 mm 130w laser to cut foam board to the perfect profile of the roof, then I used hot glue to fix the profile to the roof
glued in position
front half fiberglass done and half the foam board removed
foam board removed ready for the back fiberglass and foam board inserted into the window gap
back fiberglass done
finished 4 piece mould ready to make more roofs
