Starting my showcase of MetroX scans. A lot of people have just received their scanners and there will be a lot of these popping up. I also want to use this to highlight issues I’ve seen with some of the modes pop up.
One project I was waiting for this scanner to show up for is an axle I want to build for my truck. Axle was free to me since it was pulled off a truck that was in an accident. I knew that the axle was bent, but I wanted to do a scan to see how bent it is.
Feature tracking in Full Field mold with black object setting. It did pretty well. I had to take a lot of frames out of this scan though where it had troubles with some features and started scanning and offsetting. I wish there was an easy way to “mark” when you see this to make it easier to go back in and find the key frames to delete. Tracking was ok, it seems much better on my Miraco. I’ll get into a comparison I did between the two and tracking on another part.
It did pretty well picking up casting text and even the chipping paint off the tube on the right side.
Fused
All of scans merged into one. I played with using a combination of full field with markers as well as crossed. One thing I noticed is that the software would seem to stall out. I would move the laser back to an area that was marker rich and it would instantly jump to that spot. It seems like you need a LOT of markers for the crossed and parallel laser to work well.
As I said before this axle was in an accident. The diff nailed a boulder and caused some damage. You can see in the scan and using QuickSurface just how low that area is in comparison to the rest of the diff cover surface
Before scanning I 3d printed some caps and pulled a string tight in the center of the outside of the axle. Measuring on the inside of the diff with another 3d printed piece I made I can see that it says the axle is 3/8-1/2" out of alignment at the diff.
I wanted to confirm that I could get a similar number with the scanner. I built pretty much the same setup in cad where I created a cylinder on each end of the axle and created a line in between. I then created a sketch on the inner bearing race area and measured between that center point and my line going from end to end. The result was 0.4522" just under half an inch which my string measurement gave. It was also off in the same direction as expected.
Next steps are to determine where exactly the bend is in the axle. The scan was oriented so that the diff cover surface was aligned with the front axis. This becomes our zero plane. Drawing a straight line along the axle housing, I can see that the housing is straight and does not have a curve to it. I can measure the angle at which the whole axle is cocked relative to the surface. I can see that it is 2.15deg.
Did you use QuickSurface or QuickSurface Lite
I’m curious to know how much use QuickSurface Lite is, as QuickSurface licensing is a bit hot for my use case at the moment.
The pictures you see in this one are actually from Solidworks with the Xtract3d plugin. Similar but a little different from Quicksurface. It is much more reasonably priced at $180 usd for 3 month license.
Quicksurface pro has a lot of functionality, most of what I don’t know how to use. I have years of Solidworks experience so it is more comfortable for me to work in that environment vs quicksurface. I actually haven’t played with QS lite so I cant comment on the differences. I think it lacks some of the surfacing capabilities in lite.
Project of the day. I have this mtn bike hub that I need to take apart. There is a lock ring on the inside, but I needed a way to hold the hub so I could crank on the lock ring.
Scanned using auto turn table with a bit of scanning spray because its black and shiny.
Not a complex one, but I had broken the handle on my bicycle spoke tension measurement tool. The other side was intact still, so I took it off and scanned it. Did a few scans using parallel lines on the turn table
Did some experimenting with the new Revo Metro Software. Scanning was really nice with it. It picks up markers waaaaay better than before. Feels more like using the Miraco now. I did notice that there is no number to pick in the meshing option. Probably to make it easier for people and just mesh based on your fusion settings you picked. Overall Software was running fast and had zero issues. I’ll give global markers a try as I know some previous versions stuggled with that. Scanner is finally working how I would have expected it too, only took us a year to get there
I did that the new software has some issues picking up around the markers. It kept giving this square box around them where it wouldn’t pick up in the preview. But in the raw data it was fine. Not sure whats up with that.
Been working on turning an old truck into more of a offroad vehicle. Part of this build is installing some custom switches on the inside. I have a overhead console that has an area that is not being used and has a plastic cover that fills the void. My plan is to use this area to hold a wireless aux switch board.
Scans were done using the turntable in auto mode and merged together. Then brought into solidworks using Xtract3d. I’ve been playing with Geomagic Design X, but just keep going back to Xtract3D. Probably because I am more comfortable in the Solidworks workspace.
