The software do not resize yet the way it should , it is not fixed yet .
It is not your fault.
It works best right now with 1920x1080 resolution .
Revo Scan version: V5.0.2.214
System : Windows 10 Pro 22H2. ASUS X370 PRO, AMD AMD Ryzen 7 1700X, 32GB
Scanner: MINI
Your feedback & suggestion:
The merge function of RevoScan 5 works well, when the scans have approximately the same orientation. However, the feature option and the marker option fail completely if the object was scanned in a different position. (e.g. rotated 180 degrees). Since I want to use the scanner to produce spare parts, I normally need scans from all sides.
To solve this problem, I currently export all scans as a point cloud and use MeshLab’s Align function to merge the scans into one object. For this purpose, the scans are to be roughly aligned and then the align process to be initiated. This can be done several times and thus the result can be improved step by step.
The quality of the result is displayed as a numerical value. Then I import the point cloud of the merged scan back into RevoScan 5.
It would be handy if the merge function of Revoscan 5 would be improved so that it is comparable to Meshlabs Align function.
Hello @Revopoint-Jane ,
I’ve a question or better a suggestion for RS5.
Is it possible to integrate the control not only for 2 axis turntable also for the big turntable? Maybe also in combination with the new auto-turn-table scan introduced with MetroX?
Maybe a control of turntable could also be a feature for Miraco.
Thanks,
BR Flow
Hi @theFlow
Thank you very much for your advice! We’ll get back to the R&D team and see if we can implement it in a future software update.
