I have a Pop 3 pro and scanned the bust with the kit. Tried to scan another object after the update and nothing is working. It doesn’t have enough points. I tried to rescan the bust and the same thing happens not enough points. I tried to recalibrate it and nothing. turned it on and of. Disconnected and reconnected nothing seems to work. What am I doing wrong? It work once and nothing now. Redownloaded the update and installed didn’t uninstall. it tells me “not enough point clouds captured”. I uninstalled and loaded the previous version 5.5.5.0 I think and still it doesn’t see anything.
Are you sure you don’t set it in marker mode ?
If you set on general feature and nothing in the viewport
Please contact customer@revopoint3d.com for technical assistance .
Well could you please give me instructions on how to not set it in marker mode. I tried everything, clicked every setting to try to scan and nothing I did worked.
Please share the screen of Revo Scan after you connect your scanner to it
Put a white paper A4 in front of it at excellent distance and take a screen shot if it and upload so I can see what is going on the screen .
Check the section here for tutorials and how to use it proper
If nothing is showing in the preview you should already contact customer@revopoint3d.com
That what the technical support is for .
Don’t wait for too long since since Revopoint is preparing for Chinese New Year holidays
I don’t think the depth camera is working. I have contacted the support. Its sad I literally used this one time. Why is the Scan box in the upper left corner have a line through it? Haven’t had any success in changing that.
As I suspected the hardware failed since the Depth sensors are not active .
You probably will get replacement on this one.
There is nothing else to add to it .
Just follow the tech support advice from now on.
Can not post a link to access as it is in a school drive I will post from home account this weekend sorry.
Please follow the tech support via email , they do not check the forum on your replies here.
You need to communicate direct with them to get things done, technical hardware and warranty issues are resolved only via customer@revopoint3d.com
