Hello Everyone !
I’d just like to show a small project I started months before I know I’m even buying a Revopoint3D Mini but wished I’d had it !
The scanned item is a Runcam Hybrid II now sadly discontinued
I built a solid model of it in Fusion360 mostly manually using digital calipers and the common sense.
Originally I found that a 3D printed housing I designed would not fit over it there are too many interference’s. So I set out to verify why.
I’m not patient. So it was still attached to drone. I’m to lazy to un-solder the wires.
I couldn’t wait for proper scanning spray so I use the generic foot powder spray.
I first tapped off openings and lenses. I tried to press tape into round mount holes. You can see this. I used the normal scotch tape. You can see layers in the scan. Even serrated edge. Just did it on dinning room table moved scanner over cam taped to dot platform by hand. No special lighting. Made several scans of different types. I don’t need a complete scan just as many feature as possible.
My original model was a bit off. The scans verified this. Lens placement was not correct. Body shape was also not so good. But again the 3d scans help to correct this immensely!
I corrected my model. Housing fit is now excellent.
