MetroX - I need large scans with NO details
I am scanning things as large as chainsaw, and I don’t want the details I really just need the shell to import into Fusion 360 and build supports around the “chainsaw” what are the lowest settings I can use to make this process faster and my machine not try and pick up every detail?
Change the preview distance to 0.5mm to 1mm.
Then when you fuse the point cloud. Use 0.5mm to 1mm.
Meshing would probabky be around level 5
