Merging questions again
I am a new user (Range). I am trying to use the merge function but it seems poorly documented. I have several scans that overlap. All have been fused. However, I can only seem to be able to work with one scan at a time. How do I get the others to appear in the list of files to be Select Files to be Merged under the Merge tab?
Another question: On the Home page, is it possible to just remove a project from the list? It seems like deletion is the only option.
If you delete the project it normally will be gone together with everything i side , it is a history list … open the project and delete or add individual scans inside the project .
You can now import all files into your projects, more than 1 … recommended no more than 9 scans under one project
