Where is the point cloud data stored on Android? Navigating to Android\data\com.revopoint3d.revoscan\files\revoscan\project, I can find no ply, obj, or stl files. Do you know where my point clouds are? I had an older version (HandyScan) and didn’t have this issue.
Thank you,
Josh
Hi @lakfdj
Handy Scan did not had any projects stored on the mobile devices.
On the new Revo Scan only projects are stored on the mobile device , no obj and no stl.
To have ply files stored in your mobile project , you need to fully process the project first , or import it to computer , process then export whatever version you need what is better workflow since you will get better quality and accuracy .
Thank you, @PUTV ! After going through the fusion and mesh processes within RevoScan on my phone, the .ply file now shows up in my phone’s file system. Inst the past, I was able to get .ply from HandyScan, but they were located at handysmart/data/“projectname”.
Yes that is true but that already old app, before the project files was empty after ( no data), now you have all data available and can process on your computer .
Glad you found everything
