Mini 2 is here.
Go check it out at the links below.
Global: https://bit.ly/3Uktmw0
Cat on bike Statue
Size - 100mm tall by 75mm (roughly ruler measurement)
The surface is smooth, it is the color that makes look like its textured.
Mini 2 is here.
Cat on bike Statue
Go check the MINI 2 out at the links below.
Small Locker/Tool box Key
Size - 55mmx25mm
Just a random key i found. Probably from one of my old tool boxes.
The goal here was to capture the key portion not necessary the handle.
Mini 2 did a great job.
You can even make out the engraved numbers on it. I was surprised as they are not deep and it had aesub on it.
All details are there and looks great.
Blow off valve (BOV)
Size - Ruler 80x86x90
Beautiful scan, very clean. Top screw is about 5.5mm diameter.
Xbox controller battery cover
Size - 55x43x20mm
Scan then flip and scan again to capture all edges.
Merged
Great job!
Screw #12 x 1inch
Size - 4.75mm diameter x 40mm long
Sprayed with Aesub
Positive Cast of clear retain in food grade silicon.
Size - EST 70x50x15mm
The silicone is transparent and jelly like jello, Aesub was used.
Scan captured my jagged cuts
Well done, Jermaul.
Thanks for sharing Jermaul. How does it compare to the MINI for user experience.
It is better. The fov is larger, so it is easier to scan items that are on the large size for a mini.
And the IMU actually removes some missed tracked frames.
That’s great news ![]()
