Shipping: I’m satisfied with the shipping. Could of had better information, but I guess it is expected.
Windows PC:
Initially meets my expectations.
My windows computer can handle the 1amp requirement and everything works good after playing with it for a bit. I noticed dark colors may be a problem, but I will need to practice more. Also scanning slow is kinda hard, I am thinking about attaching the scanner to my video camera stabilizer to see if it helps.
Android Samsung galaxy s21:
Initially fails my expectations. My phone cannot handle the 1amp requirement, expected. I connected through wifi mode, acceptable method of connect, easy. The USB connect mode doesn’t work right now because my phone power, I’m planning on buying a powered USB hub. The y connectors don’t seem to work. I’m looking for some recommendation for products. If the wifi works just as well as the USB, wifi is fine. I am able to connect to the android app and power the scanner using USB power supply with wifi mode. Although I cannot scan anything. The app is not crashing, but the scan button does not seem to work. Maybe a different version of the app will work. Currently the android does not work for me, app version 1.5.
Let’s talk together, I like the device so far. The expectation is for software improvements. Thank you to the revopop team so far!
