I’ve tried both my POP3 and range with the android phone and the power stick connected to revoscan version 5.07 downloaded from the android play store . The power lights come on on the scanner , but the phone screen says that no scanner is connected. I tried the scanner with my laptop and revoscan version 5.1.360 and everything seems to be working fine with the USB cable . Not sure why both scanners are not being seen by my phone ?
Not all OTG supports that kind of connection , and that has to do with your phone …
All my Android devices don’t , include tablets . It only support connection via WiFi .
USB or WiFi will give you the same performance, so try connecting via WiFi to make it works .
I did mannage to get it to connect with wi fi . Thanks
That is good to hear @windsor !
Happy scanning!
