Ideal environment for good consistent turntable scanning
Long and short is my dental desktop scanner has bitten the dust and frankly it wasn’t very good to begin with. I am looking at either a Miraco or maybe a Pop 3 Plus. The scan subject will be gypsum dental models, dental wax ups, and 3d printed dental models. What I am wondering is what is the ideal environment to set up the scanner and turntable for these scanners? My desktop scanner had its own light sources and blocks out most other lights, has a black anodized background behind the scan subject, and a set distance, so in my mind I’m thinking that is kind of the type of environment I should be trying to replicate, but I actually don’t know. What are your guys thoughts?
I don’t recommend MIRACO or POP3 for scanning dental models, go with MetroX for best results or MINI 2
It will give you the best results .
You can scan in darkness or in controlled light environments, making sure you are away from Windows and direct windows lights or direct sun light.
Make sure your environment lighting don’t use any light that produces string yellow tones, preferable cool toned LED lighting if needed or dimmable environment lighting to avoid interior on with the projectors blue light , since yellow tones absorbing blue .
Thanks for the input. Of those two options, what do you see as the pros and cons of either?
Not much to debate, just the resolution and accuracy is just better , infrared scanner usually create some noise and that is normal , blue light scanner don’t and for dental scanning it is preferable to get the best smooth surface and details without artificial noises as much as possible.
Blue light scanning is just more detailed and that what you need.
MINI 2 actually is perfect for it , but MetroX offers higher resolution results so much better in Auto mode .
Here example of scanned acrylic model dentures with MetroX by me in Auto mode
That looks as good as any of the medit units I’ve used. I’ve had some experience with a blue light scanner in the past (BSB DS-3D) that struggled to be able to scan wax rims. Have you experienced any of that with those two models?
Yes wax runs are an issue for infrared and MINI 2 .
MetroX can handle it better , also great to scan full acrylics , gumps or teeth itself.
Both materials are absorbing so any infrared or regular blue light scanner will have issue.
But there is a solution , you can always get fine 3D spray , mostly the transparent are great , it just mate slightly the surface what is already great if you get issue and don’t add to the dimensions.
But for scanning plaster casts they are ideal.
So I guess MetroX will be your answer if you going for the hard scanning surfaces.
You’ve been a lot of help. Thank you so much.
No problem , if you need anything don’t hesitate to ask.
Hey, been about a month. Got a MetroX finally and am hoping to play around with it this weekend. Kind of wondering what primary scan mode you have found works best for the plaster models on the turntable?
For the use of the dual turntable you need activate it and use Auto turntable mode , it will give you the best finest details , great for smaller objects with features or with markers.
Remember to lift up your casts slightly up from the surface of the turntable , in the rotation settings set how many shots you need , usually around 35
Click the play button and let it handle making sure the distance is on Excellent between the center and the scanner.
Actually real easy process here and best results for what you need.
After scanning clean the fused data from lose points and overlapped points and mesh it at the same Grid settings as your fusing settings , for example Fuse was set at 0.08 mm, use the Grid at 0.08 mm ( never set above 0.08 mm but you can go slightly lower like 0.07-0.06 mm
Practice with it , the best way to learn faster and if you run into troubled let me know .
And congratulations on your new tool !
Thank you so much. I’ll let you know how it goes.
I got to screw around with it a little and have gotten a few mixed results so far. I don’t have anything great to lift it off the surface and haven’t delved into the settings completely yet, but I did get one scan that looks pretty great, so I’m excited. I’ve got one more dumb question for you though (and yes, I’m sure this is dumb because I am certain it is staring me in the face and I just don’t see it) but how do I combine multiple scans of the same model? I want the bottom of my bases to show up like yours.
Hi!
I hope you don´t mind me joining in.
Merging process is explained here from 7:00 on.
No question are dumb, "who ask for a way, don’t get lost "
Follow Ivan’s post and video above .
You can check also Mini tutorials here
Beautiful, thank you.
Not at all. That playlist looks exactly like what I needed. I very much appreciate you sharing. Thank you.
Good morning. It looks good. I’m considering purchasing a Mini 2 for dental scans. Do you think it’s the best model for this purpose?
Hi @lucaldini25
If your budged allows you , please consider MetroY Pro or at least MetroX , it produces better results under Auto turntable than just Full Field using Mini 2.
I tested it out the other day , where MetroY Pro was definitely a winner of the best fine details from all Revopoint scanners to date.
Dental objects need precision , I do dental scans as well . If your budged allows that , go for it !
Thanks for the reply, I could definitely get the Metro Y Pro, the more powerful model. My scans need to be taken with the scanner fixed on a tripod and the object rotating on the turntable. I imagine I could use a cable to connect the scanner for better data transmission? I’m wondering if the turntable is controlled by the scanning software or is it independent?
