After updating Revoscan to 4.2, it became very unstable.
The quality of scans has also deteriorated.
Or rather, it stopped scanning properly.
I want to download an older version of REVOSCAN.
is there somewhere?
Hi @miwa Revo Scan 4.2 is the most stable and best working software since Handy Scan .
I tested each of them since the first release and I know exactly what quality they can deliver in each version and what don’t .
You need to proper setup the new gain settings to get the perfect scan out of it , just clicking auto is not working anymore , you need actually to select just the surface area and after that switch to Manual and continue scanning ( if the object is just in one color )
However I experience scanning issues with the last firmware update .
I also found out that after firmware update the device must be calibrated , as my went from 0.0200 to 7.8000
So I suggest you to makr calibration test first and check the values and if the values are below 0.09000 , reinstall the new software and try again .
Check also the Starting Point/Download section in the forum and see if early versions are still available . However they are not optimal and do not deliver proper point clouds the way 4.2 do .
Also if your object lost tracking it has nothing to do with the software at all but with the object itself and if course the gain settings , distance etc …
where to download version 4.2?
On the official revopoint3d.com website under download , but remember not all scanners works with 4.2 proper , that include Range and POP3 that was not made to use with 4.2, your quality and functionality will suffer .
Best 3D Scanning Software - Revo Scan 5 the latest old RS version is 4.3.2 and there are no older version to download than that .
Does anyone have copies of the old software installers available? I have made the mistakes of: 1) updating to the latest version (5.4.8), and 2) deleting the previous installation EXEs.
The Revopoint download page appears to no longer list past versions.
Hi @itslow next time just change the name of the already installed folder of RS5 to for example RevoScan5-Old before installing a new one , and the old version will be not affected . You can use as many installation as you want .
So what happened to the new version ? It is a great update !
It’s been quite a while since I last used it, but I seem to recall the older version having more control when it came to aligning and merging. Unfortunately, without the ability to go back I cannot confirm.
The new version was improved very much especially advanced mode fusing for Mini and Pop series .
I think one of the best updates do far .
There was no more functions under merging before , same functions since December last year .
