How to use scanned texture?
I just got the miraco and it is my first scanner: what should I do to import the scanned texture in a program like blender? Thanks
First you need to import the project to computer , process it if you did not yet and export textured model as OBJ , it will create 3 files Obj+MTL+Textures , then import to Blender and follow Blender settings …
When I export as obj I actually only get the mesh file as .obj, no MTL or texture file…
First create Texture and then without changing Render tab export Textured mesh from export menu .
It works I just did it 5 times today .
