Hi everyone,
Just received my scanner and I did a first test, without reading the manual, just plugged it in my pc and started to scan.
First result: better then my €15.000 FastScan!
I am impressed.
Erik
Hi everyone,
I am impressed.
Erik
Hello @PodoTools
I am impressed to hear that! Thank you for your return. can i abuse your patience and ask if you could post a scan of the same object made with your expensive scanner and with the pop to have a comparison?
Big thank you in advance
Hi Zoltan,
I scanned a foot imprint in foam with my Polhemus FastScan that I bought more then a decade ago for 15000 €. (Today I think the price will be lower)
Green is POP, blue is FastScan
I am trying to connect the scanner now to my Samsung Galaxy S8, must look for more info to get it to work on my phone too
Hi, Podo Tools:
Impressive results, but you should search for Samsung here on the forum as most have had problems, especially with a USB connection. Apparently, most of the Samsung phones cannot provide enough current to operate the POP, so you are likely to be more successful using the Hotspot. To that end, be sure to turn WiFi OFF (also Data Saver, if applicable) before setting up the Hotspot.
Jeff
Hi Jeff,
I have no idea how to set up the hotspot for connecting my galaxyS8 to the RevoPoint scanner, and I cannot find accurate instructions.
Any tips were I can find step by step instructions for this?
Thanks in advance
Erik
I have an HTC phone, so I can’t tell you where to find everything.
From my experience and what I have read (Android only):
You should now be ready to experiment.
Jeff
Thanks Jeff.
I did all that already but it did not work.
I will give it another try soon, maybe I did something wrong.
But thanks again.
Erik
Hi @PodoTools
Thank you so much for sharing your scan results here.
For Samsung phones, we noticed some users had problems in using the software. So we develop a special version for Samsung users to use, you can check and download it in this post: [Special Android Version] New Android Handy Scan (V1.6.5.20210525) for some users - #3 by giorgio
Besides, when you choose Wi-Fi mode, please noted that you need to connect the POP to a power bank so that it will have enough power supply. (Not connect it to your phone directly)
Please check if it works, if no, we will help you, please don’t worry.
Cassie
Hi again,
Thanks a lot for the share, it’s like awesome, this shows that the price is not everything
I finally got it to work on my Samsung.
The hotspot setting that I missed was to allow all devices to connect, not only specified devices (the default setting on my phone).
I will post the results when I have done more tests.
Thanks for the help.
Could you specify that only the POP can connect? I know of at least one person here who should like that (he’s really insecure about security).
Jeff
No, allowing only a specified device means you have to have to enter the password in that device as far as I understand it.
You cannot enter a password in the POP.
That does not sound right. If the Hotspot is created with a password, then any device that connects to the Hotspot must provide the password.
To limit connection to only allowed devices, the Hotspot much have a list of the accepted device IDs (in this case, the alphanumeric text string we see each time we have to approve the connection attempt).
Jeff
Hello,
I don’t really understand your screenshot, but for the password and name you can change them with windows 10 application in USB , you can put up to 64 chars for more security.
Have a nice day
Thanks for the info.
The screenshot shows the hotspot setting tha allows all devices to connect to the phone’s hotspot.
Erik, I have an old Fastscan! were you able to get yours working with Windows 10 or 11?
It worked fine under Windows 10, have not checked it out under 11, I do not use it any more. Range won the competition in scanning footcasts, mostly because I do not have to worry about metal in the surroundings.
I will see what it does under 11 if you want.
OMG that would be so cool. No one has a fast scan anymore and support is non existent. I’ll PM you if that’s OK. Thanks Erik.
Just a note @routb3d
Yes please PM others about scans that are not part of Revopoint community as that is against the forum TOS.
