POP2 WIFI and IOS?
Hi,
Thrilled of this scanner… I’ve been doing fun things with it.
Can someone explain to me what the WIFI claims are about? Can I connect to it another way than using the cable? The official website says its some iOS connection which is a bit strange to me.
Why iOS? If it’s on iOS can we get the same on android? Historically I’ve never owned a Apple product; only android. Heck I even opt to root mobile devices from the Google stuff.
I’m just under some idea that maybe there’s a battery in the scanner and it has some ability to be used without the cable?
It is just a network connection but only between your computer and the scanner .
Connect your scanner to a power bank or charger then go into WiFi setting and look for Revipoint network , you can connect and use it without cable also on android
Read the Start Guide for more questions
Thanks. You’re right. I haven’t really read the guide. Just kinda started using it out of the box every time I get one.
The one thing I’m liking is the revopoint software seems to be getting slightly more stable. I started on the Kickstarter on the Pop 2 USB wide connector
