I happen to connect the Miraco Pro to the PC and use the revoscan software, the distance in near mode stops at 120 - 300 while with the Miraco the distance is 100 - 300 no problem for the far distance, another issue when I activate the color mode with the PC it is not possible to select 4K or 8K
No it is not possible to scan using 4-8 K
You need to do it direct on Miraco and import the project.
The scanning via PC is not a standard feature but a bonus.
There is not quality difference and you should avoid to scan via PC to save your USB port and MIRACO’s battery life if possible.
This indication which is a “bonus” where it is described, when I connect the Miraco to the PC the display says that it is possible to use the Miraco in PC mode but it does not specify WITH LIMITATIONS.
