Hi, I am over from Perth and need to check the calibration of my Miraco Plus. Unfortunately I didn’t bring the Calibration Board with me. Wondering if anyone in Melbourne would have both Near & Far Calibration Boards I could use for 30 minutes of so to check my scanner’s calibration?
Hi @Hughesy
You can check the scanner calibration in both modes by seeing the behavior of recognizing markers .. the best way
If you have no calibration boards under the hand.
If you have no markers with you draw a black circles
on a white paper and set the scanner at 90 degrees above it to see if it recognize them .
Making sure you set the mode to Markers.
Bad calibration will have issues recognizing markers no matter in what position the scanner is to them.
