Just few remarks:
1 - It would be nice to be able to cut one surface without cutting the face behind too. Atm if I have a cylinder and I select and cut the front surface, also the one on the back will be affected, and I don´t understand why.
2 - Sometimes there are artefacts on the surface, because create other surfaces and the smooth brush doesn´t work anymore. Other tools to manipulate the surface like the smooth brush are needed.
Hello could you help me because I install the new version of rhe software on my pc but now I can’t connect the Miraco Plus to mi computer and the message said that the computer couldn’t connect to the cameras of your miraco and you should restart the scanner.
But I made that a lot of times but it still doent works.
hi.
I had this problem when I connected my Pop3 scanner.
I found out that the antivirus is blocking access to the scanner camera. I turned off the antivirus and everything worked.
