I did try (several times) to start new projects. Deleted all the old scans and rescanned. Same outcome. I’ll have to rescan the fender again - it’s odd that the scanner can read and manipulate the data and the import seems to be where the problem arises.
Hi, I was able to install this but I’m using mac OS 10.15.7 but it does not want to start as it needs OS 11, I’m using an older mac for scanning ! where can I find the older version as it has been overwritten by this new one.
There should have been a check before it started installing . now I’m blocked.
Also I’m not able to install this Mac OS 11, too old workstation but still working fine…
I rebuilt it using your code and it still didn’t work. I was able to read the mesh file with Instant Meshes and convert it to a quad mesh and get that into Fusion. So the file isn’t corrupted per se. The work around is fine for now.
was not able to install windows update… if i open the revo scan software, i push the update button the the weblink leeds to china and no update it processed…
Can you help with a link for this update, i do not want to install completely and erase all projects…
this error is shown:
We will check this out for you. You can download the one directly from our official website, and you won’t lose the original scan data even if you re-download it.
