WIFI 5Ghz NETWORK NOT FOUND
I have two scanners, a range 2 and a Miraco pro 32GB. The range 2 sees the network and 5Ghz while the Miraco only sees 2Ghz. I have no limitations on the router (ftitzbox). What could it be? Another question: when I do a color scan and use the Miraco, the white LEDs remain fixed, while on the renage 2 they flash like other scanners I have seen.
regards
The LED are fixed to prevent flashing people in the eyes as it can be disturbing , it was created on purpose .
I have no idea why it see only the 2Ghz network , I actually never payed attention because I use it mostly only for updates .
I will check and let you know
Thanks for the info, I imagined that was why, it was actually annoying, just curious why only the Miraco doesn’t flash, I also own a range 2 and it flashes and previously a pop 3 and it flashed too
regards
We preferred the no flashing version after long testing , easier on the eyes !
