Hello, I received my Mini 2 on Tuesday. I’ve been trying to get the object in the images to scan. The scans lose tracking every time. The partial scans I’ve been able to get have no detail. My goal is to scan 1/32 model aircraft and print them at 1/18 scale.
Looking for any pointers. Thank you!!
Add additional objects on the bottom to stabilize the tracking , try to use s single shot mode , works better on featureless objects .
You loosing tracking on the skinny edges as there is nothing to be tracked
The market points are too closer to each other and not in a unique pattern
Get rid of markers add more elements will works better
If you work with markers like this, I’ve found that too many markers cause jumping. So there was always a minimum distance between the markers.
